Accessing "Connections" in the website causes "Internal Server Error , An error has occurred"
I have installed DVLS 4.5.0.0 and set up a new Database where this workes fine
But if i change database in DVLS under Server Settings to the database moved from old SQL server the error happens when trying to access "Connections" in website.
Using DVLS with RDM client and the old database all seems to be working fine.
Is there any log file that gives more information than "Internal Server Error , An error has occurred" ?
I will ask our support team to contact you about this.
Could you please check in the DVLS logs if there is something relevant about this issue?
Please post the details of the error if you find one.
Please consult this online help page on How to enable the Devolutions Server Logs.
Érica Poirier
Hi
Going to "View logs" all is empty , and hitting "Refresh" gives med error:
Unable to connect to your data source
Must declare the scalar variable "@RepositoryID"
and this in the details:
System.Data.SqlClient.SqlException (0x80131904): Must declare the scalar variable "@RespositoryID".
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at System.Data.SqlClient.SqlCommand.ExecuteDbDataReader(CommandBehavior behavior)
at System.Data.Common.DbCommand.System.Data.IDbCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset, DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.Fill(DataSet dataSet)
at Devolutions.RemoteDesktopManager.Business.DataSources.DatabaseConnectionDataSource.GetData(String sql, IDbDataParameter[] parameters)
at Devolutions.RemoteDesktopManager.Business.DataSources.SQLServerLogSubDataSource.GetServerLogs(Nullable`1 category, Nullable`1 messageType, Nullable`1 fromDate, Nullable`1 toDate, String userName, String text)
at Devolutions.RemoteDesktopManager.Managers.RDMSLocalManager.GetServerLogs(Nullable`1 category, Nullable`1 messageType, Nullable`1 fromDate, Nullable`1 toDate, String userName, String text)
at Devolutions.RemoteDesktopManager.Forms.FreEmbeddedServerLogs.LoadLogMessageRowGrid()
ClientConnectionId:680e468a-16e1-4a8f-93cd-b71bac88f5c9
Error Number:137,State:2,Class:15
I managed to access the DATA Source logs via the webiste "server/dvls/administration/data-source-logs
And i found this that appears when the error appears
ArgumentOutOfRangeException - Length cannot be less than zero. Parameter name: length at System.String.Substring(Int32 startIndex, Int32 length) at Devolutions.Server.ConnectionNavigationManager.CreatePartialTree(SessionContext context, PartialConnection partialConnectionBase, ConnectionInfoEntity[] connectionInfoEntities, Boolean isPrivate) at Devolutions.Server.Controllers.APIControllers.v2.BackendApiController.GetPartialConnectionTree(String breadcrumb) at lambda_method(Closure , Object , Object[] ) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass10.<GetExecutor>b__9(Object instance, Object[] methodParameters) at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ExecuteAsync(HttpControllerContext controllerContext, IDictionary`2 arguments, CancellationToken cancellationToken) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Web.Http.Controllers.ExceptionFilterResult.<ExecuteAsync>d__0.MoveNext()
The database seems to not be at the correct version. With DVLS version 4.5.0.0, the database must be at version 315.
Please make a backup of this database first and then from the DVLS Console, update the database by clicking on the Update Database button in the Database tab of the Server Settings.
Érica Poirier
About the error ArgumentOutOfRangeException - Length cannot be less than zero, this issue has been fixed internally and will be available in the next version of DVLS.
Érica Poirier
Hello Erica
Databse upgrade has been done before. I did it again but still same problem.
Also i might say that im running RDM 12.5.8.0 since there was problem with importing more than one user to the database before that you fixed
We have been able to reproduce your issue about the Server Logs error and a ticket has been submitted to our engineering department.
Are you interested to try a patch of DVLS about the ArgumentOutOfRangeException error?
Érica Poirier
The "Going to "View logs" all is empty , and hitting "Refresh" gives med error" issue has been resolved and will be available in the next RDM beta build.
Stéfane Lavergne
Hi Erica
Yes I am interested to try the patch for DVLS to adress the ArgumentOutOfRangeException error
Could you please execute this SQL Statement on your SQL database?
How many rows does this statement return?
select * from dbo.Connections where ConnectionType = 25 and (GroupName not like '%' + Name or GroupName is null or GroupName = '')
Érica Poirier
Hi Erica
That SQL Statement returns 8 rows
These rows contents incorrect information in the GroupName column. When you click on the Connections menu to view the sessions, these groups cannot be displayed in the tree view and you get the ArgumentOutOfRangeException error.
So it is possible to fix these 8 rows to resolve the issue.
Are you available for a remote session?
If so, please write an email at support@devolutions.net and we will schedule an appointment. If you are available for the next 30 minutes, just mention it in the email and I will send you the link to do the remote session now.
Érica Poirier
Good morning Erica, we are having the same issue. Can you please provide the solution, so that we can implement to resolve?
Hi
I managed to get this solved by editing the entries returned from SQL statement select * from dbo.Connections where ConnectionType = 25 and (GroupName not like '%' + Name or GroupName is null or GroupName = '')
I edited them in RDM client so that the name of the entry in "Tree browsing view" and the Name that is seen when editing the entry match exactly with lower and upper cases.
I also hade one entry that didn´t show up in the SQL statement but after finding that one, which had the same name but with difference in upper and lower cases I now can access "Connections" in the website.
Great workaround. Thank you for sharing it.
