How to manage Web Logins with three credentials?
Good morning,
we are now very far with our tests but one thing I can't find: We have some weblogins, that require 3 credentials (CustomerID, Username, Password). How can I modify the template to hold all 3 informations and to fill in correctly with the browser extensions?
William
All Comments (4)
This is something that is not supported. Do you have an url where we could test that? Perhaps we can cheat and use the domain field with the customerid
By the way we just need the url (in private) and not the real information. We would test the autofill.
Sorry that I meddle - but we managed this with the "domains" field;
For example:
This need to customize the html control id`s - we have 5 or 6 websites where this "workaround" works ;)
Min
Hallo Min_destens,
ich unterstelle mal, dass Du deutsch sprichst :-)
Vielen Dank für die max_imale Hilfe, werde das gleich ausprobieren.
@David: Thanks for the fast reply, I will try Min's suggestion - if it's not working, I come back to you.
Thanks both of you,
William
