Protect local settings from normal users without admin rights
Hello from Austria,
is there a way to hide the applications settings like 2factor and offline access from normal users, so they cant change this? We're using a SQL datasource.
Thanks a lot,
William
Hello William,
The best way to restrict the applications settings is to use our ADMX file or if the computer is not on the domain you could also restrict by registry.
Please find the information in that help topic.
Let me know if it does not solve your issues.
David Grandolfo
Hi David,
thank you for the quick answer. The topic is for Remote Desktop Manager - does this also apply to Password Vault Manager?
William
You are welcome, For PVM please go to C:\Program Files (x86)\Devolutions\Password Vault Manager\Policies you will find the same policies.
David Grandolfo
