How to assign Custom icons to entries using PowerShell
Custom icons are stored in the datasource as a Base64String.
Assign a custom image to an entry.
Use the View > Entry History > Compare method to see what the string is for the custom image. (there may be a better way to obtain this)
I copied and pasted the following attributes: <Image> and <ImageMD5>
then use this code to assign that icon to your entries:
$Sessions = Get-RDMSession
foreach ($session in $Sessions) {
$session.ImageName = $null
$session.Image = [System.Convert]::FromBase64String("paste the string copied from between the <Image> </Image> tags here")
$session.ImageMD5 = 'paste the string copied from between the <ImageMD5> </ImageMD5> tags here'
Set-RDMSession $session
This will change all entries, don't forget to include a filter for the entry type as required.
I changed the default orange icons for the blue variation but then discovered they didn't have a blue alternative for the default Device group / folder type.
Of course I didn't discover this until I had changed every other entry type to blue.
If anyone wants a blue device icon here is the code:
$session.Image = [System.Convert]::FromBase64String("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")
$session.ImageMD5 = 'c2d4b16a0091b447b155db46651d6d78'
All Comments (0)
