Using 2 x 2FA with FallBack
is it possible to use 2 Versions of two factor authentication. One primary and a secondary if primary is not avaliable?
Regards, Bernd
All Comments (7)
I don't think it's possible. We could add a one time password alternative though. What do you think?
How the User get the one time Password?
Sorry for the confusion. It's not a one time password but a one time code list:
https://support.google.com/accounts/answer/1187538?hl=en
This could be generated from your account.
So if I´ll create a new user with 2FA, then he will (if switched on) get a List of 10 (or 20 time codes), which he can use if 2FA does not work correctly. If the List is empty, he´ll get or can request by his admin a new List of Codes.
That sound´s good for me.
Yes exactly. It's not implemented but this is something on our list.
Is there a timeline available?
Regards, Bernd.
Unfortunately I don't have a timeline.
Sorry about that
Ends in 6 days
