Error Silent on a few PVM clients
3 users are receiving Error Silent whenver they update a lot of data on PVM.
I just attached the capture screen with the error they are receiving.
What could trigger this Error?
thanks
Helder
All Comments (4)
I'm unable to open the attached files. Could you send an email to support at devolutions.net?
Sadly there seems to be an issue with the forum and I cannot get to the images.
SilentErrors should not be displayed to normal users, they are meant only for diagnostics purposes.
Unless there's a bug, you should see them only if the debug level has been set to include silent errors. You can do that in the profiler or in File-Options.
Do you know if they have turned on that level?
Also, could you include the text of error message?
Maurice
Three of those a related to running out of memory, and in three different areas of the application.
Can you describe what you mean by "a lot of data"?
Maurice
They are entering a lot of data entry for a few folders.
Adding also some screen captures
Ill check with them if they have other applications running at the same time.
