Note / Secure Note
Note / Secure Note
Not useable on Android. What editor does it need, if any? How do you create secure notes?
All Comments (1)
Hi Sung,
Thank you for your feedback.
Currently, secure notes created on the Windows platform can be read without special formatting (special formatting is lost).
However, the format that is used is not fully compatible on the Android platform and that is why
secure notes cannot be created on Android at the moment. We will add this task on our todo list
and investigate if something changed that would now make it possible.
Best Regards,
Nicolas Dufour
