RDMS Authentication problems
Hello together,
we have the following szenario:
We are planning to integrate the RDMS in our company, to manage several RDM-Databases in different locations.
For testing reasons, i have a got an VM without connection to our Doamin.
I have installed the RDMS in v.2.5.2.0 and the RDM in v.10.6.3.0.
I have set up an IIS Website and an SQL Server 2014.
I was even possible to generate an Database through the RDMS Setup at the SQL-Server.
The Identity-settings for the RDMS Website-Application Pool are "NetworkService". I have granted "db_owner" permissions for "NT AUTHORITY\NetworkService" to the RDMS Database at our SQL-Server.
Because we have no Domain access at the moment, i have set up authentication permissions for "Devolutions Server custom user", "local machine user" and "Database user".
Now the problem is the following: If i try to login to the RDMS webinterface with ANY kind of user (i have tried any kind), i get the message "Login failed, ivalid user or password !". This happens with local users, DB users and also with RDMS users i have added through the RDMS console.
I have allready read some Threads and tried the solutions but the login still doesn´t work.
Can you guys help me out here ?
Thanks alot !
Florian Schneider
edited by FSchneider on 6/19/2015
All Comments (11)
