Ver 4 does not work with RDM ver 7.6.2.0
Is this a bug or a feature ?
All Comments (5)
What problem do you have exactly? PVM 4 is based on the RDM 8.0 in beta.
That is very nice but I use RDM ver 7.6.2 and I cannot upgrade more due to license issues (no more money ;)) but I still have a license for PVM and I've upgraded to ver 4 and now I lost the integration between the 2 programs.
When I try to use a RDM entry that uses PVM entry it will prompt me as if PVM is close.
Please assist ASAP...
Sorry about that. Could you try this update build:
http://passwordvaultmanager.com/download/Devolutions.PasswordVaultManager.Bin.4.0.0.0a.zip
Working now, thanks...
Absolutely solved the problem. Thanks a lot.
