How to copy hole DB from Local Data to SQL Data?
It would be nice if different Data Sources like the local data Source Data and the let's say shared SQL Data source has a option to copy paste records and structures from one to another without having a big headache.
Let's say you are an IT Director or System Engineer and have sensitive data store in the local DB or another SQL DB and have one which is shared for the hole IT team on the SQL Data source.
Now how can you pick and choose data sets and structures to be copied in between and how can you perform that?
It would be nice if both is possible hole tree structures or just one single data set.
Lars
All Comments (4)
Have you tried the menu Edit->Clipboard->Copy?
Is there a shortcut key to do this?
With the new version, you have the ribbon button but there is no shortcut. I try to not add to many shortut because they could conflict with an opened RDP session. It's always complex to manage.
It would be easy if there was a simple way to put focus out of the session onto RDM (like clicking on the UI. Of like in VMware just press Ctrl + Alt)
So any key would go either in the session or in RDM itself depending where focus is.
Only selected key combinations should act on RDM even if the session is focussed
