Read Only Issue
Read Only Issue
I am using a SQL database with my PVM for Mac client. I can view information, but cannot edit. Any ideas on what the issue is?
All Comments (1)
Only a few situations allows you to view the information but you cannot edit them.
Did you try right-clicking or ctrl+click and select the edit entry option of the menu?
Did you check your user security to make sure it allows entry editing?
Tell me if you need anymore help
Benoît Sansregret
