Forum / Remote Desktop Manager - Beta
Small issue with installation path
  • Create an Issue
  • Cancel
In the RDM options, under 'Path' then 'Configure Installation Path' I noticed the RoyalTS item is looking for an executable that no longer exists (RTS3App.exe). The executable for that application is now called 'RoyalTS.exe', so even if I point it to the proper path, RDM cannot detect the application.
Clock6 mths
This also applies to the Hyper-V item (looking for vmconnect.exe but is now vmconnect6.3.exe). Presumably others as well.
Clock6 mths
Thank you for reporting this! An improvement ticket has been assigned to our engineering department in order for them to add the option to "override" the default installation path for these applications. I will contact you as soon as I will have more information on that matter.
James Lafleur
signaturesignature
Clock6 mths
This is now fixed internally.
signaturesignature
Clock6 mths
