Forum / Remote Desktop Manager - Support
VMware Remote Console / PowerCLI, Hyper-V on same system
  • Create an Issue
  • Cancel
For an RDM installation on a Windows 10 OS that already has Hyper-V enabled, if you try and install PowerCLi to get VMware Remote Console support for RDM, the PowerCLI installation will produce the following error:
PackageManagement\Install-Package : The following commands are already available on this system:'Export-VM,Get-Cluster,
Get-VM,Get-VMHost,Move-VM,New-Cluster,New-VM,Remove-Cluster,Remove-VM,Restart-VM,Set-VM,Set-VMHost,Start-VM,Stop-VM,Sus
pend-VM'. This module 'VMware.VimAutomation.Core' may override the existing commands. If you still want to install
this module 'VMware.VimAutomation.Core', use -AllowClobber parameter.
This is not an RDM issue but is due to the fact that Microsoft and VMware use the same commands. Given that this is RDM's methodology for a VMware remote console session, does Devolutions have any suggestions ? One of the posts in this thread https://communities.vmware.com/message/2786013#2786013 suggests a couple of workarounds but I'm not sure if this would help with RDM.
Clock1 mth
I must first tell that I like this message. You found an issue but also guide us to a possible solution, thanks.
I will discuss the approach to use the fully qualified module name to avoid the name collision with the engineering department.
ex.: VMware.VimAutomation.Core\Get-VM
I inform you in the next steps.
David Grandolfo
OFFICE CLOSURE!
Although our various support queues will be monitored for emergencies, Devolutions' offices will be closed on Monday, May 20, 2019.
signaturesignature
Clock1 mth
I had a chat with the engineering department. We are glad to announce that we are currently working of replacing PowerCLI. We will use our own SDK for Vmware Console and when launching VMRC. After this integration we will work on Vmware Synchronizer.
This feature should be released soon, please watch the release note at https://remotedesktopmanager.com/release-notes .
David Grandolfo
OFFICE CLOSURE!
signaturesignature
Clock1 mth
That's great David.
Another example of the outstanding support of RDM.
Clock30 days
Good news we released yesterday RDM 2019.1.20. The VMWare integration does not require PowerCLI anymore. You can download RDM at https://remotedesktopmanager.com/Home/Download
David Grandolfo
OFFICE CLOSURE!
signaturesignature
Clock4 days
Thanks David,
I installed RDM 2019.1.20, created a new VMRC entry, entered the vCenter 6.0 name and the VM name. When I attempt to connect I get "The object has already been deleted or has not been completely created". The VCenter/VM names are good, my credentials are good and I can connect to this Vcenter using the RDM remote dashboard connection type.
Any thoughts ?
Clock4 days
Could you send us a print screen of the entry, I would have to look with the engineering department about this issue.
You can safely send us your information by email at ticket@devolutions.net .
David Grandolfo
OFFICE CLOSURE!
signaturesignature
Clock4 days
