Forum / Remote Desktop Manager - PowerShell Repository
Power Shell Set Property
  • Create an Issue
  • Cancel
Im trying to set an SSH entry to use a key file in the repository:
$keyfile = Get-RDMSession | Where-Object {$_.Name -eq $SSHKeyFile}
Write-Output $keyfile.id
Set-RDMSessionProperty $Session.ID -Path "Terminal" -Property "PrivateKeyType" -Value "Link"
Set-RDMSessionProperty $Session.ID -Property "PrivateKeyConnectionID" -Value "$keyfile.ID"
The write-ouput returns the correct value.
when the entry has been created and goto properties i get an error "Unable to find the private key entry. This setting will be lost"
Clock2 yrs
Normally, to have the UI refreshed after some operation made in a PowerShell script, you have to update the UI with the Update-RDMUI cmdlet. Could you please add it at the end of your script and see if you still have the issue?
Érica Poirier
signaturesignature
Clock2 yrs
Hi Erica,
Took a differnet approach to this but still cant get the entry correct:
i am now trying to edit the XML :
[xml]$xmlProperties = $Session.Terminal
$xmlProperties.Host = "$HostIP"
$xmlProperties.PrivateKeyPromptForPassPhrase = "False"
$xmlProperties.PrivateKeyType = "Link"
$Session.Terminal = $xmlProperties.InnerXml
$xmlProperties.PrivateKeyConnectionID = "10a46b93-52fb-471e-82d9-00baea99df03"
$Session = $xmlProperties.InnerXml
But it still doesnt work, can you help please.
Clock2 yrs
The PrivateKeyType is an Enumeration type. So you cannot set it with the "Link" value.
Here are the values you can set in the PrivateKeyType property.
0 = NoKey
1 = File
2 = Data
3 = Link
4 = MyDefault
5 = PrivateVault
So, to set it to Link, you must set this property to the value 3.
Set-RDMSessionProperty  $Session.ID -Path "Terminal" -Property "PrivateKeyType" -Value 3
Érica Poirier
signaturesignature
Clock2 yrs
