Forum / Devolutions Password Server - Support
problem with upn-suffixes and domain logins on DVLS 4.5.0.0
  • Create an Issue
  • Cancel
any news for fixing the problem with domain logins and upn-suffixes on DVLS 4.5.0.0?
Clock3 yrs
For your information, DVLS version 4.6.0.0 already supports the usage of alternate UPN suffixes.
I am afraid to say that there are still some minor issues with that version. Here is a short list of these issues that has been fixed internally.
- The Automatic User Creation works only for UPN username format. NetBios or Username will not work and wont create user accounts.
- The Automatic User Creation wont work if an AD Group is configured.
- Some problems with the backup feature on specific configuration.
- Some minor issues in the web interface.
If you are not concerned by those issues, you can upgrade to version 4.6.0.0 and RDM 12.6.6.0.
Otherwise, I will recommend you to wait for the next version of DVLS that should be released shortly.
Érica Poirier
Happy Holiday Season!
Although our various support queues will be monitored during the coming holiday season, Devolutions' offices will be closed from December 24th, 2019, to January 1, 2020, inclusively.
signaturesignature
Clock3 yrs
