Forum / Remote Desktop Manager - Support
Duo - Trusted Devices and Networks
  • Create an Issue
  • Cancel
I am using the Duo integration with RDM and it's awesome.
Duo has a feature that will allow users to save their devices for X days/hours to avoid re-authenticating.
They also have a feature to trust networks.
I tried both of these and I am not seeing any changes in the RDM login process.. when it does the Duo authentication.
I'm guessing these features need to be integrated into RDM?
Brian
Clock4 yrs
Indeed it's not integrated. I will check with the devs if it's easy to add.
signaturesignature
Clock4 yrs
I'm actually working on the trust networks feature and I'll have a look at there trusted devices feature.
It's plan to be part of the RDM 12 released.
Best regards
Clock4 yrs
