Forum / Remote Desktop Manager - AddOns
SecureCRT and KeePass - auto fill don`t work
  • Create an Issue
  • Cancel
Good day !
I am trying using RDM 10.0.4.0 with SecureCRT add-on and KeePass Plugin.
After creating ssh session (SecureCRT) and point to use credential repository (KeePass) i am try to connect.
Unfortunately autofill credentials don`t work - autofill only username in SecureCRT prompt, but no Password.
Clock6 yrs
Does it work if you hard code the password in the securecrt session?
signaturesignature
Clock6 yrs
Thanks for reply.
Yes.
If i use RDM functionality with it`s credential manager everything working done.
I think this is the KeePass plugin issue work with SCRT.
Clock6 yrs
I will assign this to one of our dev. Thank you
signaturesignature
Clock5 yrs
I just released a new version of the add-on (2.0.2.0).
In fact this issue was for all credentials repository.
André Sanscartier
signaturesignature
Clock5 yrs
It`s work now !
Thank you very much !
Clock5 yrs
