Forum / Remote Desktop Manager - AddOns
OpenVPN Session problem with OpenVN 2.0.9
  • Create an Issue
  • Cancel
I have installed OpenVPN 2.0.9 and I can use my .ovpn file outside of RDM, but when I configure (manually, not importing) the OpenVpn session in RDM, I always receive following error:
Options error: Unrecognized option or missing parameter(s) in myfile.ovpn:2: <connection> (2.0.9)
Use --help for more information.
Any Idea ?
thanks in advance
regards
Davide
<em>edited by dadep on 3/16/2011</em>
Clock9 yrs
This add-on was not created by me and the guy that did it is no longer responding to my email. I will try to help you the best I could. Can you post a printscreen of the message ? Also, when you use it externally, what command line do you use?
signaturesignature
Clock9 yrs
The error is
Options error: Unrecognized option or missing parameter(s) in client.ovpn:2: <connection> (2.0.9)
the external command is:
openvpn --disable-occ --config client.ovpn
where client.ovpn is:
client
dev tun
proto udp
remote xxx.xxx.xxx.xxx 2481 (xxx.xxx.xxx.xxx is ip address of vpn server)
ca ca.crt
cert client-cert.crt"
key client-key.key"
ns-cert-type server
comp-lzo
verb 3
<em>edited by dadep on 3/23/2011</em>
Clock9 yrs
Can you send me an export of you VPN session configured. You can remove all your server information in it?
What is the option disable-occ? I can't find it. Does it work in command line without this option?
signaturesignature
Clock9 yrs
--disable-occ Don't output a warning message if option inconsistencies are detected between peers.
attached my RDM OpenVpn session
This is the RDM session file
client
<connection>
remote xxx.xxx.xxx.xxx 2481 (xxx.xxx.xxx.xxx = ip address)
proto udp
</connection>
dev tun
proto udp
ns-cert-type server
comp-lzo
ca ca.crt
cert client.crt
key client.key
<em>edited by dadep on 3/24/2011</em>
Clock9 yrs
I have the same problem,
I show you my information for details the problem.
I use my open .ovpn file
#OpenVPN Server conf
tls-client
client
dev tun
proto tcp
tun-mtu 1400
nobind
remote*********.fr 1194
pkcs12 *********.p12
cipher AES-256-CBC
verb 3
ns-cert-type server
This is the error log message :
Options error: Unrecognized option or missing parameter(s) in mandrake51.fr.ovpn:2: <connection> (2.0.9)
Have you got an idee for this error ?
thinks
Clock9 yrs
Can you try this add-on revision?
signaturesignature
OpenVPNAddOn.zip
Clock9 yrs
With the new addon I've got following errors.
InvalidOperationException - There was an error generating the XML document.
at System.Xml.Serialization.XmlSerializer.Serialize(XmlWriter xmlWriter, Object o, XmlSerializerNamespaces namespaces, String encodingStyle, String id)
at System.Xml.Serialization.XmlSerializer.Serialize(Stream stream, Object o, XmlSerializerNamespaces namespaces)
at System.Xml.Serialization.XmlSerializer.Serialize(Stream stream, Object o)
at RemoteDesktopManager.AddOn.OpenVPNAddOn.OpenVPNConfiguration.ToXml()
at RemoteDesktopManager.AddOn.OpenVPNAddOn.OpenVPNEditor.SaveFromControls()
at Devolutions.RemoteDesktopManager.Frames.VPN.FreAddOnVPNSettings.SaveFromControls(VPNConnection vpnConnection)
at Devolutions.RemoteDesktopManager.Frames.ConnectionSettings.FreVPNConnectionSettings.SaveConnectionFromControls(Connection connection, ConnectionType connectionType, String connectionSubType)
at Devolutions.RemoteDesktopManager.Forms.FrmConnection.SaveConnectionFromControls(Connection connection)
at Devolutions.RemoteDesktopManager.Forms.FrmConnection.butOk_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
InvalidCastException - Unable to cast object of type 'RemoteDesktopManager.AddOn.OpenVPNAddOn.OpenVPNConfiguration' to type 'RemoteDesktopManager.AddOn.OpenVPNAddOn.OpenVPNConfiguration'.
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationWriterOpenVPNConfiguration.Write4_OpenVPNConfiguration(Object o)
Clock9 yrs
If you create a new VPN entry, do you get the error ? Does it happen only when you edit. I will do some test on my side.
signaturesignature
Clock9 yrs
I reproduced the problem and it's happening when you have two OpenVPNAddOn dll installed. Delete the one in your application installation folder and replace the one in %LocalAppData%\Devolutions\RemoteDesktopManager with the new version.
signaturesignature
Clock9 yrs
I've done, but now it seems doesn't works the SAVE button in the Add Host window of the new Addon, instead, the CANCEL button is working.
Clock9 yrs
I fixed the problem. Can you try this version.
signaturesignature
OpenVPNAddOn[1].zip
Clock9 yrs
Is not working, but I have found the problem.
The RDM addon write the <connection> and </connection> raws, that are not correctly interpreted by openvpn engine. If you want to try, create the openvpn configuration inside RDM and run the created config file directly from openvpn and you get the error message.
If you modify the config file removing <connection> and </connection>, it works.
client
<connection>
proto udp
</connection>
dev tun
proto udp
ns-cert-type server
comp-lzo
ca ca.crt
cert client.crt
key client.key
Clock9 yrs
I found what you were talking about and I don't know why it was coded this way. I made the change, can you try this version?
signaturesignature
OpenVPNAddOn[1][2].zip
Clock9 yrs
now it's working. Thank you for your job.
Davide
Clock9 yrs
Thank you, I will release it officially.
signaturesignature
Clock9 yrs
