home recent topics recent posts search faq
DEVOLUTIONS :: Forum
user:
psw:
| lost password | register
Messages in this topic - RSS
Home » Remote Desktop Manager - Beta » Fixed: Event- Variable does not work
6/19/2010 3:53:17 AM
Blindfox
Blindfox
Hi There,
i try to start a event "before connection".
It worked without variables, but if i want to push a variable to the VBS Script i get an error.
The script:
c:\TEST.vbs $SESSION_ID$
When i start the rdp session i get the following error:
Unable to execute the script file [c:\TEST.vbs f6170165-7f6d-4ace-9010-4d806643d9da]
It looks like the variable worked correct (it was changed into the id), but then it cannot start the vbs.
Any hints, tips?
Thanks!
Blindfox
edited by Blindfox on 7/7/2010
permalink • reply with quote
6/19/2010 6:42:00 AM
dhervieux
dhervieux
Administrator
Can you try to put the variable between quote. Also can you try to execute the same thing in command line and see if you get the error ?
Devolutions inc.
6/19/2010 11:47:09 AM
Blindfox
Blindfox
thanks for the quick response!
if tried the quotas, same error, now with quotas:
Unable to execute the script file [c:\TEST.vbs "f6170165-7f6d-4ace-9010-4d806643d9da"]
When i start a cmd with:
my script works.
Blindfox
6/21/2010 5:07:14 AM
dhervieux
dhervieux
Administrator
What OS do you have ? Is it a 64 bits version ?
Devolutions inc.
6/21/2010 5:07:55 AM
dhervieux
dhervieux
Administrator
CAn you check also the application log, it's in the menu Help, maybe there is more details of the error ?
Devolutions inc.
6/23/2010 9:29:36 AM
Blindfox
Blindfox
yes its 64 Bit, Windows 7 Professional.
Here´s the log:  (Translation from German, the first line says: "The system couldn´t find the specified file")
[23.06.2010 18:20]INFO System.ComponentModel.Win32ExceptionBig Grinas System kann die angegebene Datei nicht finden
   beiSystem.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
   beiSystem.Diagnostics.Process.Start()
   beiSystem.Diagnostics.Process.Start(ProcessStartInfo startInfo)
   beiDevolutions.RemoteDesktopManager.ConnectionEvents.RunScriptFile(String script,Boolean waitForExit, Int32 timeout, Boolean runAsAdmin, Int32 pause)
I try to run it as Administrator: same error.
I try to run it with a path without blanks (h:\test.vbs): same error.
Has anybody this working with Windows 7 Pro 64 Bit?
THANKS!
Blindfox
6/23/2010 12:21:36 PM
dhervieux
dhervieux
Administrator
I might know what is the problem, the application is 32bits and I think that because the the Windows folder virtualization, the process is unable to find windows scripting host application. I have a solution for that, I will add it to the next beta
Devolutions inc.
6/23/2010 12:22:27 PM
dhervieux
dhervieux
Administrator
Devolutions inc.
6/24/2010 7:37:23 AM
Blindfox
Blindfox
that would be great!
Thanks, David!
Blindfox
7/1/2010 6:59:26 AM
Blindfox
Blindfox
Hi David,
i tried the new beta, but unfortunately it doesn´t work.
Then i tried to check it out on a Windows XP 32 Bit System: it do not work, too.
You can try it for yourself: generate a test.vbs file with the following lines:
set WshShell = CreateObject("WScript.Shell")
for i = 0 to WScript.Arguments.Unnamed.Count -1
WScript.Echo WScript.Arguments.Unnamed(i)
next
You can try the functionality if you start the test.vbs from a cmd with some parameters:
test.vbs hhh
the vbs starts a msgbox with: hhh
If you start it from the event it doesnt start. It creates an error:
Unable to execute the script file [v:\test.vbs "Mydomain"]
Exactly the same is on the XP 32 Bit and on the Win 7 64 Bit System.
Could you test the script?
Thanks,
Blindfox
7/1/2010 7:10:59 AM
dhervieux
dhervieux
Administrator
I will retry it today and come back to you.
Devolutions inc.
7/1/2010 7:38:19 AM
dhervieux
dhervieux
Administrator
You're right, the application was not handling correctly the parameters, I updated the binaries, but not the version. Can you give it a try ?
http://remotedesktopmanager.com/download/Devolutions.RemoteDesktopManager.Bin.5.8.0.10.zip
Devolutions inc.
7/2/2010 5:39:09 AM
Blindfox
Blindfox
Hi David,
THANK YOU!!!!!
With this Version it works! (Tried on Windows 7, 64 Bit).
Thanks a lot,
Blindfox
7/2/2010 5:42:40 AM
dhervieux
dhervieux
Administrator
I must say, thanks to you. Your were very helpful with this bug.
Devolutions inc.
Powered by AspNetForum v.6.1.6.0 © 2006-2009 Jitbit Software
